Driverside Headlight
NOFX0617
32
Jul 8, 2004
Bakersfield, California
Hey guys I am having a problem with my driver side headlight. I put some projector headlights that I had gotten used from a friend on my car when I got it. A couple months later the driver side projector burned out. So I bought a brand new set of headlights and its been a couple months now and that same projector has burnt out again. Has anyone else had this problem?
sounds like a moisture problem, make sure its sealed good or the moisture will burn them out, I have had this problem on my old mazda
no not touching the bulbs....I will just replace the bulb and see if it happens again....I tested the wires and they are all good. Its probably just bad luck.
