cutting off the cat
jl98
54
Mar 2, 2004
sioux falls, South Dakota
anybody have any good tips on cutting off my cat? pros and cons? HP gains? it seems like such a waste living in a state with no emission laws and keeping it on. any help would be greatly appreciated.
I don't understand the question.
If you want to unbolt the cat and bolt on a test pipe which will replace it and lessen the restriction, you can do that. There are bolts and they may be a bi*** to get off but they should allow you to remove the exhaust without any cutting.
Now, my bolts on the otherhand didn't want me to do any unbolting and since I was replacing the entire exhaust system, manifold, turbo, o2 housing, downpipe and catback I went to home depot and rented an electric hand held saw for the day, purchased several metal blades for it and went to work cutting mine apart because the GS-T exhaust system goes over the rear axle and need to be seperated somehow to allow it to come off.
So, if you actually need to do some cutting I would suggest going to home depot and seeing what they offer in the daily rental of a nice hand held saw. If you just want to remove the cat then jack that car up, or find a lift, and get under there with some liquid wrench or wd40 and soak the bolts overnight. Then get a breaker bar and go to work. Many vendors offer test pipes, or you could have a local shop fabricate one.
-T
i just mean getting rid of the cat altogether whether that means simply removing it or cutting it off or however. I know that would free up some power wouldn't it?
