Control Arms????
AleksLukic
62
Aug 14, 2004
Des Plaines, Illinois
I was curious, and I may be flamed for saying something like this, but here it goes. I believe its the control arms that aaffect thi, but If I was interested to get wider wheels besides arranging the offset is there a way the control arms can be modified so that it can hold a wider wheel. I just wanted to know what can be done if there is anyting to handle a wider wheel because I'd like to get something wider for the rears, and give it a real menacing look. any suggestions? :confused:
The best/easiest way I know to fit the widest wheels possible is to measure and get the right offset and roll the lip out of the way that goes inward on the fenders to gain more clearance. you can find a bunch of info on rolling fenders, people usually heat them up and roll a bat with duct tape on it to not damage or crack the paint. good luck!
Besides changing offsets and rolling fenders is there a way to modify that long arm right behind the wheel so that a wheel can fit deeper in the wheel well?
