broken bolt in turbo
If he managed to snap off a turbo bolt inside the housing, you might be SOL. We once ran a solid one piece SS turbo gasket that warped and caused two of the turbo bolt heads to shear off. Our machinist could get one of the two bolts out, but the other one he couldn't. I think that the OEM bolts are chromoly or some other similarly hard metal. It's worth trying, but you might not be able to get it out. If you were talking about another bolt then sorry, disregard my post.
OH-one more thing. I can't see any pics, but it's possible the previous owner used SS ARP bolts, in which case you could probably get them out. The SS bolts always snap inside the housings because they expand at different rates than the manifold and turbine housing when heated.
regardless of where it is, take it to a machine shop. they won't charge you to much to do it and its better to just pay up and save yourself the headache. i tried to remove one myself and i ended up just buying a new hotside.
the owner before me was mad stingy with his money and was a afro engineer i know there not ss for sure
well i heard the 16g and 14b parts are the same in this case so if thats the case im gunna just swap the turbins on to that one and put it in the 16g housing but my first thought was any good machine shop should be able to get it out for less than 10 bucks or so
If he managed to snap off a bolt for the oil return line that gets trickier. That means either it was a bad bolt or he torqued the sh*t out of that bolt, or both. I would try extracting that, like you said, any good machine shop should be able to do it. The good news is that unlike the turbo bolts that's just a regular hardware store grade bolt, not some super strong steel alloy.
alex at dogbox told me it was hardend steal im hopeing he is wrong
Hmm, maybe that one is, I know that the bolts I used were just SS bolts, but perhaps you had a different one. Regardless, I seriously doubt that it is as hard as the turbo bolts are.
Its hardened cause its been heat cycled on the turbo/manifold. Good luck getting it out.
It can be done with a carbide tipped drill bit, but it isn't going to be fun.
ok so today i found out its a peice of a tap that some jackass broke off in it=.
the turbo is shot so im moving on up to a t4 60 trim from persicionturbos internal waste gate
A tap? Shit, that isn't good. It can still be done but pray to god that was a standard HSS bit and not carbide.
