Brembo rotor stock replacement/ stud question
ILLiCliPSE
1,576
4
Jan 11, 2003
Boynton Beach, Florida
Im ready to order some new brembo c.d.'d and slotted replacement rotors for my 96 gs. I dont know much about brakes, but im assuming i would need new studs. What kind of studs should i get (if there are different kinds LOL) and where should i get them? Ill be using stock calipers if that helps :confused:
and yes i searched...
Thanks,
Brian
The Brembo rotors should fit exactly the same as your stock rotors. Changing your studs would not be necessary, unless of course there is something wrong with your old ones.
K..sounds good thanks man :cool: :thumb:
Anyone else have replacement rotors?? :dsm: :talon: :laser:
i just put brembo slotted rotors on my car bc my stockies made my car shake :notgood: i put endless pads in with the stock calipers and it works GREAT!
They just slip right on in place of the old ones. I'm running the Brembo slotted discs with EBC greenstuff pads. I abuse them pretty hard and they're holding up well! This is my 3rd rotor/pad combo and so far the best.
