braded oil line bolt size needed ???
dsm4life
1,323
3
Sep 24, 2002
Philadelphia, Pennsylvania
I have a SS braded oil feed line for my turbo that we COULNT use. So we tapped into the VC for oil no biggie. Now can someone tell me the size of the bolt that the other end of the line runs into (the oil housing i guess) so that i can unhook the SS line and just plug that hole ?
..i am not quite sure which area you are referring too, so this may not be any help, but the nuts that thread into the points where the line feeds into the turbo on the one end and feeds into the connector that goes into the block on the other end are 7/16ths on my ss line. if you are talking about the size of the threads on the connector that attaches the line to the block i am not sure.
i tried at least :)
just reread your post, realized you are talking about that connector peice, and i have no clue what size it is. maybe take it to a hardware store and find a nut that fits it to get the size
your gonna be using oil from the valvecover?.... when you ordered the ss line, you probably didnt order the one for your car... the 2g kit is long enough..the 1g kit isl ike 18" and is made to feed from the head.
i didnt use the install kit. I had a braded line on from t25 them i changed oil points. I guess i will have to take it off and play with it . Was just trying to save some time
this...............
just to let everyone know for other readers , the plug size is 3/8's , thanks RRE :thumb:
