interceptor
- 303
- 0
- Mar 6, 2003
MIAMI,
Florida
Any one heard of this or is using this product?
Defiant, i have no idea what your talking about.
This is the 420a section which is n/a motor (I know, you know that). The spark gap spec for this motor is .044. So naturally when people build a low compression motor they still run the 044 gap. you either need to install a more intense coil of spark cd box. The alternative is to mock the 4g63 platform and drop the gap to 028. THIS DOES NOT ALWAYS SOLVE THE ISSUE. the 420a Coil is not as potent as the 4g63 coil.
Terry
Are you telling me that closing down the spark gap isn't part and parcel of a turbo conversion? I'm very surprised to hear this. The "low compression" goes out the window when forced induction comes in.naturally when people build a low compression motor they still run the 044 gap.
The combustion chamber doesn't care what block it's in. It does care about having a pressurized intake feeding it, whether it was built to be a turbo or not. The higher cylinder pressures will call for a narrower gap because air's electrical resistance rises as it is compressed.
