420A Auto to Manual, no speedo or reverse lights!
Brad Bell
202
11
Aug 15, 2014
Levant, Maine
I did an automatic to manual swap on my 1999 eclipse gs n/t through the instructions by 2gnt - http://www.2gnt.com/?d=ATMT I hooked up the wires for the speedo the wires that I think are the correct ones at the ecu, but I don't know for sure. Does anyone know the exact wires to tap off of? My reverse lights also don't work, although there is power coming off the plug from the automatic transaxle switch. If someone could just explain to me the exact wires to use, that would be great!
-Thanks
I have helped a friend do this once. Did you make sure to cut the wire from the TCU and ground the other end? I can not remember what it is off hand but ill look for it and see if i can find it. That was the problem we had for the reverse lights.
