91 eclipse gs starts then stalls
91dsmeclipse
181
Mar 22, 2004
Siloam Springs, Arkansas
alright here is the problem when i drive my car and its fully warmed up and im driving the car starts to like stutter u can call it and then when i stop at a light it does it and stalls the car out and the car has to sit for about 10-20 min before it starts again but when i try to start it right after it stalls it starts but sounds like only one or 2 cylinders are working and it shakes then stalls. i changed all the vacuum hoses the fuel filter and air filter it still does it and there are no vacumm leaks does anyone know what it might be thanx
check the MAF
i did check it and it was good but i didt put a hair dyer to it to see if the voltage is moving
Check your ECU leaking Caps, my car was doing the samething and it stopped when i changed them
Unplug all your injectors, wiggle them around a little, and plug them back in. This fixed the same problem on my car yesterday.
thanx for the link i think im going to go check my ecu right now i hope its not leaking caps but i got the fix thanx 16vtawd that link is great
i just took my ecu out and checked it and the ecu is in perfect condition no leaking caps or burn marks at all.So it must be something else.I was wondering i heard about fuel cut may my car be doing the same thing. only mods i have done to my car is a performance muffler the free air can mod and i took the silencer out of the maf but my car was doing it even before i did those things
