6 bolt or 7 bolt engine
scaldwellk
39
May 17, 2005
Shippensburg, Pennsylvania
Can any one tell me if I have a 6 or 7 bolt engine from my VIN? I am told that the 92 had both?
VIN: 4E3CT64U3NE029323
I want to rebuild engine, but I am unsure of engine.
Please help if you can.
Look at you oil pan, if it is flat by the timing belt side then it is a 6 bolt, if has a hump then it is a 7 bolt. Also you should be able to tell by the date the car was made.
Forgot to ask. If the engine is a 6 bolt is there a number for the engine? I was told something like a 4G6 or 4G63, not sure?
I found that the car was made in late 91. The oil pan is flat by the timing cover. I will assume that I have a 6 bolt? Is there some where that I can buy a rebuild kit for this turbo engine?
Yes, you have a 6-bolt.
