6 blot swap need some help!!!
boosted_awd
Aug 19, 2007
angola, Indiana
alright i did a 6 bolt swap into my 95 awd talon. the motor is out of a 90 turbo eclipse. i have spark and fuel but it wont turn over. what could it be? i have a plug that i believe goes to the pressure differential sensor and im gonna put that on monday and see what happens. would that make my motor not start and if not what could it be? i appreciate all the help and info thanks
Is it not cranking at all? Or its cranking and just not starting? Like he ^ said did you rewire your CAS>
If he rewired the CAS he would have spark. The MDP doesnt have to be plugged in for the car to start. Just plug it in and stow it away somewhere. If the MAF ever fails it uses its failsafe, the MDP, to operate the car. I dont even have a vac line going to it on my swap. Does the starter spin?
it has fuel and spark. i rewired the cas. its turning over but just wont run and i cant figure out why?
