1994 Eclipse GST
Bought in Florida so in pretty decent shape rust wise. Gates timing belt /balance shaft belt. New lifters, spark plugs , head gasket , GM MAF , 50 trim turbo/ garrett internals, automatic trans. currently not working. Only goes in reverse.
Hey everyone,
This site has been a world of help for me and friends so thank you in advance. I need a little help on a "good working condition" automatic transmission I bought I few years ago for my GST since the original transmission in the car has failed and will only go into the reverse gear. The part/model numbers are different but my friend told me it will work in my GST ( He did a AWD conversion to his Eclipse) The bell housing seems to match up but if you look in the pics the connector that plugs into the gear selector/ range switch is not the same, everything else seems to match. Would this trans. possibly be compatible with my car? Thanks
