For sale Fuel pump and hanger
Walbro 450 fuel pump
$80.00
Walbro 450 fuel pump (less than 200 miles on it) $80
OEM fuel hanger assembly with 6 an feed line, oem return line, and siphon has been drilled to 1/8 to accomodate 450 pump. Missing the oem fuel connector and missing the oem fuel level sender $40
jmt2028
More from jmt2028
  • For sale 2g Water Neck/Thermostat Housing
    2g OEM waterneck and thermostat housing $60.00 In good condition, came off 1995 Eagle Talon Tsi
  • For sale 2g OEM Camshaft Gears
    2g OEM Camshaft Gears $80.00 In good condition, came off 1995 Eagle Talon Tsi Comes with OEM...
  • For sale 2g ARP Head Studs
    2g ARP Head Studs for sale $60.00 Used but in good condition, came off 1995 Eagle Talon Tsi
  • For sale 2g Coil Packs
    2g oem coil packs for sale, came of 1995 Eagle Talon Tsi $160.00Both coil packs in good...
  • For sale Spal Fans
    Spal Fans for sale11" High Flow Pusher fan $100.00 11" High Flow Pusher fan $100.00 14" Slim...
  • For sale HKS Cams B01/B02
    HKS cams part#s showing B02 and B01. 330 shipped to the lower 48. Two of the cam lobes have...
  • Wanted 1g Fwd subframe
    I’m willing to head down to southern states if needed, If anyone has a fairly clean fwd subframe...
  • For sale 2g 7 bolt engine build parts and mounts,
    All parts include shipping to lower 48 (PayPal G&S).Wiseco K597M855 piston set (new, open...
  • For sale 2g 97-99 Mpi relay
    2g. 97-99 Mpi relay. Many don’t realize the later 2g doesn’t use the same mpi as the 90-96...
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Apparently illegal to list for...
