boogst's Eclipse GST
Mitsubishi Eclipse GST
-ebay intake pipe w/ red 4" filter, -2.5" turbo back exhaust w/ hi-flow cat, -1g bov, -ngk plugs & wires, -heater hose & exhaust pipe where stock plastic uicp restriction was (under fuse box), -prothane motor mounts
Mods-EMS & Logging
-glow shift triple pod w/ boost, a/f ratio, and volt. -dual gauge cluster pod w/ autometer mech. oil pressure
cross drilled & slotted rotors
Parts Wishlist
-EVO 3 16G - In Garage, -XS-Power o2 Housing w/ Dump - In Garage, -o2 Sensor - In Garage, -Hallman ES MBC - Will be here 7-6-08, -34mm Flapper - Should be here some day..., will port out turbo housing after i get flapper
----Need for E316G Build-----
Manifold, -2.5" Custom Exhaust or 3" eBay
1/8 Mile E/T
0.000
1/8 Mile MPH
0.000
0.0 lb/ft
2G DSM
boogst
More in 2G DSM
Share this vehicle
