1995 Eclipse gsx
- Ownership Status
- Currently Own
- Year
- 1995
- Model/Trim
- Mitsubishi Eclipse GSX
- Turbo Type
- GT30 Variant
- Drivetrain
- AWD
- Transmission Type
- Manual
- Build Type
- Street
- Showcar
- Mods-Bolt-on
- Fp manifold , Garrett gt3076R . Mishimoto Rad. Mishimoto Intercooler. Jmf coolant overflow.. tial wastegate. Hks blow off. Hks hi power carbon fiber exhaust. Fic.1050 injection . Jmf fuel rail. Deutchworks fuel dampner. Deutchworks AFPR , stm fuel pressure gauges. Stainless fuel lines. Injector resistor pack. Jmf clutch and brake resovoir caps. Modified fuel hanger with Bulkheads. Evo 9 leather seats. Wedge fabrication seat brackets
- Mods-Engine
- Block
Manley forged rods, Weisco 85.5 mm forged pistons , 4 ply race head gasket, Motor gasket kit Gates water pump , Gates timing belt Arp head studs , Arp main studs, King main bearings, King rod bearings, GSC balance shaft delete kit, Machined and balanced oem crank , STM tensioner arm, STM trigger plate
Head
Brain crowler stage 2 spring, Brian crowler titanium retainers, Gsc S2 cam shaft GSC zero tick adjustable rocker and lash, Fidanza adjustable cam gears, New Oem Oil squirters, New oem exhaust/ intake valve stems and seals Shaved valve cover . Powder coated with 2 -10 fitting, Raven fab valve cover baffles, STM egr block off plate, Oem thermostat gasket, throttle body gasket, Zakee clear cam cover , ½ inch manifold spacer
- Mods-EMS & Logging
- LINK G4X . AEM wideband AEM boost. AEM oil pressure. AEM oil temp. AEM coolant temp. CAN-LAMBDA
- Mods-Drivetrain
- Shep 3 trans. Rear lsd. Jbx driveshaft carriers. Oem rebuilt tcase.
- Mods-Handling
- Tein zflex coilovers. Front and rear strutt bars.. New tie rods, control arms upper and lower. Lateral control arms.
- Parts Wishlist
- Dog box
- Background
- Bought the car 3 years ag. Drove for a year before turbo and clutch went on same drive. A simple repairs turned into nut and bolt reso.
