Garrett's 97 Eagle Talon
- Ownership Status
- Currently Own
- Year
- 1997
- Model/Trim
- Eagle Talon TSi AWD
- Transmission Type
- Manual
- Build Type
- Street
- Drag Race
- Mods-Bolt-on
- Cold air intake - Forced performance
Intercooler core and piping - vrFactory Brand
Speed Density
Thottle body - off v8/5.0 Cobra Mustang
Custom Race intake manifold - Magnus Brand
Exhaust Manifold - HAFE brand - Cast Stainless Steel , 7^cm flange
External Wastegate - 38mm turbotehnics brand (from 34mm{16G} to 38mm)
Holset turbo - hx35 7blade
Hx35 Stainless Steel Exhaust Housing - 7^cm flange, .55A/R - IWG flapper has been tIg'ed welded - BEP Brand
Custom upgraded o2 downpipe - 2.75" , w' external wastegate pumbed back in,
3" Apexi exhaust
wideband o2 sensor - LC-1 wideband
Shifter Bushing kit - RTM Brand
- Mods-Engine
- Adjustable cam wheels - Fidenza brand
Upgraded dual cam shafts 272/272 - Brian Crower brand
Upgraded head - Ported 91(1G) head
2900lbs cutch - ACT brand
lightened flywheel - ACT brand
fuel pressure regulator upgrade - Aeromotive Brand
fuel injectors (1000cc)
Fuel pump upgrade - walboro brand
All internal bolts are upgraded to APR brand
- Mods-EMS & Logging
- EMC Tuning-DSMLink V.3,
Boost gauge,
EGT gauge
- Mods-Drivetrain
- Stock
- Mods-Handling
- body kit - side skirts, rear flares, rear wing
Springs-Hypercoil springs, 2.25" x 8" – Rear 325lbs / Front 500lbs
Shocks- Front Koni's / Rear KYB's
strut tower bar-front upper
All suspension bushings changed out for polyurethane - energy suspension brand
- Parts Wishlist
- Carbon Fiber hood
Magnus Cast Manifold
Upper shock hats w bearings
- Background
- I am second owner of the car and have owned it since 2001. I do all the work on it myself (other then block internals)
