1990 Eagle Talon TSi AWD Vehicle Profile & Build Thread
Street Build
A decent autocross and time trial car, 16psi fun on the street. Classic 1995-era tech, returned to 'streetable' in final 1998 episode. Now want to address two autoX problems, make a few updates, and try it again. Girlfriend want a ride!
Silver Phoenix
Ownership Status
Currently Own
Eagle Talon TSi AWD
Turbo Type
14b
Drivetrain
AWD
Build Type
  1. Street
  2. Autocross
K&N air cleaner, internally polished turbo housings, RRE outlet housing, HKS UICP w/ DSS elbow polish, Extrude Honed intake manifold, flow balanced injectors, adjusted cam gears, Walbro fuel pump w/ wiring and kill switch, 93+ exhaust manifold w/ matched ports and O2 housing, RRE downpipe, HKS exhaust, Slippery Lizard test pipe; Catz MSX driving lamps,
Mods-Engine
stock head w/ 10mm exhaust studs, stock block,
Mods-EMS & Logging
HKS boost controller, AutoMeter boost gauge,
Mods-Drivetrain
CenterForce DF clutch, solid shifter bushings, 93+ dual-piston front brakes, DSS stainless-steel brake lines,
DSS Hi-Flow power steering pump, ES front subframe bushings, front crossbar, KYB xxx struts & shocks, H&R springs F&R, ST rear sway bar, street wheels - DP 7Jx16 - 225/50/16, track wheels - ROH Type 96 8Jx16 - 245x45/16, various chassis weight deletes, front strut camber bolts,
Parts Wishlist
All those Coolant Hoses and directly from Mitsu.
Background
Purchased new as daily driver, autocross at Cal Poly SLO and Santa Maria airport w/ CPSCC; Lone Pine Time Trials. ~65,000 miles, garaged since 1998. What's that red in the background?
  • Like
Reactions: NatFabLLC
1G DSM
Steve S
More in 1G DSM
Share this vehicle
