1991 Eagle Talon TSi Vehicle Profile & Build Thread
FWD Auto Drag Build
1991 Eagle Talon FWD
Ownership Status
Currently Own
Eagle Talon TSi
Turbo Type
GT40 Variant
Drivetrain
FWD
Automatic
Build Type
  1. Street
  2. Drag Race
Magnus Race intake Manifold, Torque Solution Thermal intake manifold gasket, OBX Racing T4 exhaust Manifold, Cometic MLS exhaust manifold gasket, Mitsubishi MLS head gasket, Custom 68-72 Napier billet wheel ball bearing T4 turbo, Tial F40 wastegate, Mishimoto 4 Inch race intercooler, Mishimoto 3 Row Radiator With Mishimoto dual slim fan shroud, HKS SSQV BOV, Ngk Iridium spark plugs with NGK race spark plug wires, 1600CC custom built injectors, Custom high flow fuel rail, AEM 340LPH fuel pump, STM 6AN Tank to Rail Fuel line kit, Gates racing Belts, Tomei Adjustable cam gears, Fluidampr crank pulley/dampener, JM Fab 300M Cop plate, Dynatek Arc 2 CDI,
Mods-Engine
Eagle forged crank, Kiggly main girdle, Eagle forged hybrid rods for 7 bolt pistons, Arias forged 2G pistons, BC stage 3 280 Camshafts, BC forged single springs and retainers, SS nitrate coated valves, Topline 3MM revised Lifters, GSC race balance shaft, ACL oil pump with straight cut gears, ARP head & main studs, King racing rod bearings, ACL race series main bearings,
Mods-EMS & Logging
AEM SERIES 1 ECM, AEM AFPR, AEM wideband, Rywire 1G engine harness, AEM 3.5 BAR / 50 PSIA MAP Sensor Kit, MAC 3 port boost controller,,
Mods-Drivetrain
Forced Four smart 75 shift box, B&M 15000 BTU transcooler, Kiggly flexplate, Traction concepts LSD, Kiggly 5 friction clutch pack, Bradco High stall converter,
EBC stage 9 Slotted Front & rear brake kits, Tech-na fit SS braided brake lines, Godspeed Mono SS coilovers, ST front & rear sway bar kit, Custom Rear Strut Bar, Cheapo Front Aluminum Strut bar for now..
Parts Wishlist
Drive shaft shop 800WHP axles
Background
I found the car in the middle of a field looking sad and figured I better change that, plans are to finish building the car and to crack 1000 WHP after a little while, this is my first car I’ve ever owned believe me it’s been a headache to get this far but worth every step of the way. I’ll get more pictures soon guys! :)
  • Like
Reactions: GReddyTalon
1G DSM
Joelito509
More in 1G DSM
Share this vehicle
