Aethro's 92'GST
- Ownership Status
- Currently Own
- Year
- 1992
- Model/Trim
- Mitsubishi Eclipse GST
- Turbo Type
- 16g
- Drivetrain
- FWD
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- Mitsu EVOIII 16g Turbo, PTE 780cc Injectors, Walbro 255 fuel pump (rewired), VRS Front Mount Intercooler, 2 row Aluminum radiator, Custom Intake w/K&N, , Aeromotive FPR w/ AN6 Line, FuelLab Filter, SnowPerformance stage 2 Meth Injection - Nozzle #3, Pro Meth fuel cell (AN4 - 3 GAL), Mamba adjustable wastegate
- Mods-Engine
- Wiseco HD1400 Pistons (86mm), 22mm Steel Tool wrist pins , Manley connecting rods (22mm floating wrist pin), Balenced and polished crankshaft, Balance shaft delete,ARP Main Studs (line honed), ARP Head Studs, Decked block and head, Cometic 86mm MLS Head Gasket, Revised Lifters
- Mods-EMS & Logging
- DSMlink v3 - Speed Density , Boost control , Innovative LC2 Wide band , Meth Injection MAP switching, SnowPerformance VC-50 Boost Gauge Meth Controller, Innovative LC2 AF Gauge, Android dual-din headuint w/ALDLDroid
- Mods-Drivetrain
- XTD Stage 2 Clutch, ACT Streetlight Flywheel, SS Clutch line. Revised fork, New pivot ball, oem TOB
- Mods-Handling
- Koni Yellow , H&R Sport Springs, Dual Piston brake upgrade, NRG Evo steering wheel w/quick release, New Axles, Wheel bearings, Tie rod ends, Sway bar links, Strut mounts,
- Parts Wishlist
- Cams!
