The Wedge
- Ownership Status
- Currently Own
- Year
- 1991
- Model/Trim
- Eagle Talon TSi AWD
- Turbo Type
- 16g
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- -Walbro 255 Fuel Pump Rewired
-Turbo Back 3" Exhaust
16g @12psi
- Mods-Engine
- -85.5
-Wiseco pistons
-eagle h beam rods
-ACL bearings
-ARP Head and Main Studs
-Kiggly Block Girdle
-BC Valves & Springs
-OEM MLS Head Gasket
-Punishment Racing FMIC
-Chase Bays Radiator
-Balance Shaft Delete
-Poly mounts
-Intake Barrier Gasket
-EGR delete
- Mods-EMS & Logging
- -AEM Wideband Gauge
-Autometer 30psi boost Gauge
- Mods-Drivetrain
- -rebuilt 23 Spline Transfer Case
-Competition Clutch- Sprung 6 puck(stage 4)
-HD aluminum Driveshaft w/ Poly Bushings
-4 Bolt LSD Rear Diff
-Shifter Bushings CNC Aluminum
-Stainless Clutch Line
-new Axles (Front & Rear)
-new wheel bearings
- Mods-Handling
- -KYB AGX Struts w/ TEIN S-tech Springs
-Powder coated black 2g Rims
-BFG Sport Comp 2 Tires
-tire size: 205/55ZR16
-strut Bar
- Parts Wishlist
- -ECMLink V3
- Background
- Well this is my 2nd DSM. Not sure what my long term goals are, but short term is to use it as a daily driver.
