'91 Talon TSi
- Ownership Status
- Currently Own
- Year
- 1991
- Model/Trim
- Eagle Talon TSi AWD
- Turbo Type
- 14b
- Drivetrain
- AWD
- Transmission Type
- Automatic
- Build Type
- Street
- Mods-Bolt-on
- Megan racing 3" downpipe, Megan racing 3" test pipe, Megan racing 3" catback.
- Mods-Engine
- NGK plug wires, NGK es plugs gapped at .028, GSC power division revised lifters, GSC factory replacement valve springs, evo valve spring retainers, GSC valve stem seals, fel-pro permatorque head gasket, rebuilt head, factory Mitsu timing belt & tensioner, gates accessory belts, '90 air cooled ofh, b&m oil cooler, 2x Moroso sealed catch cans, emission's delete, autometer boost gauge, drop in K&N air filter, restrictor removed from factory boost solenoid, punishment racing smic hard pipe, stock bov, fuel lab -6 an filter & feed line, 2g manual black top injectors, fuel lab fpr, fuel solenoid bypassed, non-cruise throttle cable.
- Mods-EMS & Logging
- 1g 5 speed ecu. GM 3” MAF w/ MAFT logging on a palm with MMCD.
- Mods-Drivetrain
- Rebuilt auto trans, bradco torque converter, bigger trans cooler, autometer trans temp gauge installed in place of cig lighter, solid driveshaft bushings.
- Mods-Handling
- 2g gsx big front brakes, slotted rotors all the way around, STM abs delete, 2g big bore master cylinder, Megan racing front strut bar, RTM racing rear strut bar, 2g gst wheels painted black.
