The [Not-So] Sh*tbox
- Ownership Status
- Currently Own
- Year
- 1991
- Model/Trim
- Eagle Talon TSi AWD
- Turbo Type
- 16g
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- BJ aluminum intake manifold
Forced Performance 68HTA turbo (internal wastegate)
Forced Performance race exhaust manifold
JM Fabrications recirculated o2 housing
Apexi down-pipe
Thermal Research & Development exhaust
Spearco front-mount intercooler
3" GM MAF sensor
Blitz blow off valve
Hallman Pro manual boost controller
PTE 680 fuel injectors
AEM fuel pressure regulator
AEM fuel filter
Walbro 255lph fuel pump w/ braided steel lines
JM Fabrications oil catch can
JM Fabrications coolant overflow
Magnecor 8.5mm spark plug wires
NGK BPR7ES spark plugs
EGR & EVAP eliminated
- Mods-Engine
- Slow Boy Stage 2 Head
Ferrea +1mm valves
WEB 272/272 Stage 2 cams
Kiggly Racing HLA pressure regulator
- Mods-EMS & Logging
- DSMlink v3 Full
AEM UEGO wide band sensor/gauge
Stewart-Warner boost/vac gauge
B&M fuel pressure gauge
Autometer oil pressure gauge
- Mods-Drivetrain
- ACT 2600 clutch kit
Symborski short shift kit
4-bolt LSD rear
- Mods-Handling
- KYB AGX gas shocks
H&R springs
Enkei Evolution 8 wheels
Bridgestone Potenza Pole Position tires
3000GT VR4 front 4 piston calipers
- Parts Wishlist
- PTE 1200cc fuel injectors
AEM high volume fuel rail
Energy suspension bushing kit
RM Racing rear sway bar
Megan Racing front strut brace
Wilwood Dynalite/Dynapro brake calipers w/ braided steel lines
Mishimoto radiator
- Background
- The goal is to get into 10 sec 1/4mi times, and do it maintaining street drivability and a relatively sleeper-like appearance.
