pauleyman
DSM Wiseman
- 11,677
- 5,531
- Nov 19, 2011
oklahoma city,
Oklahoma
I don't get it. It seems like once a week we have a post on a botched job. I'm tired or reading about it. I just wanted to share my experiences.
After 20 years and more belts than I can count I'll summarize by saying this. No matter what method you use to line up marks, put belt back on, what tools you use the following will ensure it's right.
Once the belt is on rotate the motor at least 6 times until all 5 marks line up with dowels up on the cams. (3 marks for no balance shafts).
This is NO almost right. The marks are either dead on or they are not. Period. If it's wrong you start over. NO exceptions
The tensioner protrustion must be in spec. Its either in spec or it isn't. There is no close enough. There is no almost.
Why does the manual tell you to rotate the crank? Two reasons. One to check the marks and more importantly for those that haven't figured it out, to remove all the slack from the idle side. In case you didn't figure this out yourself you may find then the tension was correct then you rotated the motor and now it isn't. Thats becuase there was a little slack on the idle side. Once I have the marks lined up I rotate the crank just a hair to make sure there is no slack on the idle side so I can set tension correctly.
Either way once you rotate the motor you have eliminated any possible slack and the tensioner protrustion will be what it's going to be and the measurement is either in range or it isn't.
I can't see any more plain objective way to state it.
I did my first timing belt job in 1993 before there were videos, forums, vfaq with nothing more than basic tools and the factory service manual which I followed to the letter. The car should run exactly as it did before. No better, no worse, no nothing.
I trust nobody but an experienced dsmer to set tension. I don't even trust mitsu techs unless I know them. I've seen too many people ignore the procedure or try and short cut it.
If any of the measurements, marks are wrong. You start over.
Once I had the belt on the first time it took me about 10 tries before I got it right because I didn't quite know how. Once I fooled with it for about 45 min I figured it out and by following the factory manual I knew it was right and had zero doubts. No "good luck" needed, no crossing fingers. It was right, I knew it, I buttoned it up and didn't look back.
I hope others do the same. Maybe this will help somebody.
