Jason84
- 948
- 3
- Jul 10, 2003
Manitowoc,
Wisconsin
well talked with a helpfull guy today on AIM. this is sorta what i came out with.
DSMotor sport
T3T4 coonversion 50 trim stage 3 .63
VSR 3 SS turboback exhaust
Flex a lite slim fan puller
Apexi AVC-R EBC
6 bolt rod bolts
4g63 main studs
6 bolt head studs
Belt kit
AEM adjustable cams
-6 fittings and hose for FPR install
fuel pump rewire kit
aeromotive adjustable FPR -6
magnecore spare plug wire set 8.5 mm comp set
NGK plug set
ACT 2600lb pressure plate
ACT full face street disk
ACT clutch alignment tool
ACT throwout bearing
New mitsu water pump kit
New front case incl oil pump gears oil pump seals
Factory mitsu engine gasket kit
RCI aluminum rad catch can
Extreme psi
Extreme psi race core kit
Walbro 255l high pressure w/ install kit
TurboSX type H RFL
Apexi super AFC fuel computer
im going to kinda do a engine rebuild (pistons/rods/cams also dont know which ones but might wait till after winter to do them) the head is going to get done to might wait till after winter.
also need to figure out which injectors to get.
also was wondering if i should stick with the 6 fuel line or go to 10 ??
if you guys think i should get different parts or something let me know your opinions.
DSMotor sport
Apexi AVC-R EBC
6 bolt rod bolts
4g63 main studs
6 bolt head studs
Belt kit
AEM adjustable cams
NGK plug set
Extreme psi
TurboSX type H RFL
