Turbo oil feed port repair
BogusSVO
5,886
336
Jul 1, 2009
Pensacola, Florida
1G Turbo Oil Feed Port Repair
I had a 1g head come in that was really messed up. At some point in time someone had tried to install a heli-coil as a repair. The heli-coil was set too deep and was just a flat out mess.
This repair has to be done with the head out the car and off the engine. Remove the HLA regulator, HLAs and oil galley plug at the front of the head.
First thing to do is remove the old heli-coil.
No way a new heli-coil will fix the oil feed port.
So I am going to use a method I have shown for an exhaust stud repair.
I drilled the oil port to 7/16
1/4NPT plug and Banjo bolt
Then tapped for a ¼ NPT , I had to make a “bottom tap” for the pipe plug
Next is to start with the normal tap, get a good start with it, but due to the step that is machined into the oil galley you cannot go as deep that is needed. So once you hit the step, back out and switch over to the bottom tap. Go slow and not too deep, the top of the pipe plug needs to lock down and stop flush with the casting, along with not blocking the oil galley that feeds the HLA regulator and cam journals.
Next is to drill and tap for the banjo bolt.
Drill all the way through the pipe plug and tap to 10 x 1.25mm
If the plug is below the head casting, take a new rol-loc and buff the aluminum away so the plug is flush and a good sealing surface.
Now clean the oil galleys with brake clean and compressed air to remove all of the metal chips from drilling and tapping.
  • For sale Carbonetics Carbon Quarter glass
    Bnew Carbonetics Quarter glass
    • jabo97gst
  • Wanted 1g Wtb: Palm pilot w/ MMCD and cable
    I am doing an old school build with my 1G and am looking for this ancient hardware. Preferably...
    • Jeff D
