2G Suspension Bolt/nut sizes.
98mitsubishigst
1,526
16
Nov 17, 2008
Pittsburgh, Pennsylvania
Hey, so im putting the motor in tomorrow and wondering if anyone knows of EVERY bolt and nut size ...
i need to know because my buddy took the suspension off and doesnt know where bolts went...
please and thanks!
40279C - M12x92.5 bolt
40286F - M12 nut
40299D - M12 lockwasher
40279B - M12x50 bolt
40299C - M12 "special" lockwasher
40286B - M10 flanged nut
40694 - M10 nut, washer assembled
40395B - M12 nut, self lock, flanged
40395C - M10 nut, self lock
32166F - M10x22 bolt, washer assembled
32166B - M12x90 bolt, flanged
32166C - M10x75 bolt, washer assembled
32166D - M10x45 bolt, washer assembled
40387B - M12 nut
40381 - M12 lockwasher
40388B - M12x135 bolt
40388D - M12x35 bolt
40387C - M14 locknut
40388C - M12x60 bolt
I hate to thread revive, but there's no need to clutter the site with another thread. Is there a member among us that knows the thread diameter and pitch of the above listed part number 40387c locknut? My 40387c decided to abandon ship during my morning commute and I need a quick replacement to get me home. Thanks in advance guys.
Apparently I have chosen the wrong nut in the diagram. The nut I need secures the lower curved control arm ball joint to the spindle. I believe it is a 22mm nut which im guessing would be a 14 x 1.25?
I don't have access to CAPS or ASA right now because I'm at work but from the info I'm pulling up in Google that nut (40387C) is P/N MU431006 and is showing up as a 12mm and flanged. So its a 12mm nut thats 8mm x 1.25mm thread pitch and you'll want a lock washer on it unless you get OEM.
:dsm:
I get MU432101 for that lock nut but nothing anywhere tells me its size. Give me a minute and I can check the size for you.
And now that site decided to work. My question, Corey, would be why you were looking up parts on a Pajero? LOL
I think this is more of what you were after: MU432101 - Front susp arm & member for Mitsubishi Eclipse MNGFLFJ - -INF ;)
For what it is worth and to clear up any confusion, the "12" listed under the spec for the Pajero nut is not the socket/wrench/head size. Rather, it is the nominal diameter of the bolt which is what you shop for when looking for specific nuts/bolts: nominal diameter (normally prefaced by M for metric bolts) x pitch x length (for bolts). The socket/wrench/head size can and likely will vary by the fastener's manufacturer.
The Pajero is a close cousin to the DSM, you didn't know that? ;)
So in this case Brian, the "12" being nominal diameter, is the diameter equal to the external diameter of the threads on the lower control arm, the diameter equal to the internal diameter of the threads of the nut, or both I guess?
:dsm:
Both -- sounds like you've got the idea.
About the only other way to state this any more clearly, the nominal dimension represents the diameter measurement across the crest of the threads on a bolt or the theoretical diameter measuring across the root of the threads on a nut.
I know it's an old thread but it's relevant. Does anyone have a diagram/list of the rear suspension bolts like above?
41393B..... M12 x 74mm
41391....... M12
41393C.....M10 x 25mm, washer assembled
41604....... M12 x 107.6mm
41605B..... M10
41605C.....M10, self locking
41306C.....M12 x 160mm
41395....... M12
41306B..... M12 x 68mm
41385C.....M14
41388C.....M14 x 93mm
41388B..... M12 x 74mm
41385B..... M12
<NEW> 41309AL and 41309AR..... M12 x 1.25mm x 74mm (the bolt without a number). This is a cone-tipped bolt.
34993D.....M14 x 65mm
41189....... M12, self locking
34993C.....M12 x 28, flange
34992....... M14
34993B..... M14 x 120mm
34993E..... M10 x 16, washer assembled
41997C.....M10, self locking
41997B..... M10, flange
41698....... M8 x 16mm
41999B..... M12 x 28mm, flange
41697....... M10, washer assembled
Due to popular demand, I present 1g AWD:
So can anyone help me out with the thread pitch for (front lower ball joint) 40387C from Post #2 in this thread? It's not M14x2.0, I think it's M14x1.5 or 1.25?
I took to Home Depot started to thread onto a M14x2.0 long enough for me to confirm the diameter. Of course it's some weird thread pitch I won't be able to get a die for.
What I get for waiting until less than a week before the first event to get the car back together.
Did you figure this out? Mine are lock nuts, but I've also seen where they can be flanged. Lowe's doesn't carry M14 nuts, and I tried a M12 bolt in the nut that I took off the curved control arm to see if I was wrong, and it didn't even touch the threads, or barely did anyways.
I haven't tried HD due to being inconvenient for the errands I was running.
**Edit: ordered a couple from O Reilly. Dorman part #433-014. It'll be a couple days since they don't stock them, but they are M14x1.5, so I'm going to bring an old lateral arm with me to see if it'll work.
Hate to reopen the thread but i cant find the thread pitch for 32166d or 32166c and m10 seems to be too small seems like a m12. But tried a m12 with 1.25 pitch and still seems too small any suggestions? Idk if the p/o tapped it or crossthreaded it or what.
32166D - M10x45 bolt, washer assembled it's listing it as an m10! If it's bigger then it's been redrilled and tapped for an m12 and it could be a 1.50 pitch,
From the #2 post...
32166D - M10x45 bolt, washer assembled​
Just making 100% certain, the M10 isn't referring to the head size (socket size) it's the shaft diameter. The M10 x 1.25 bolts have a head size of 14mm.
