seals ?awd Manuel leak transmission
Had recently replaced the left front axle shaft seal ,two find out that didn't fix my leak , still leaking transmission fluid , and when press clutch in won't go in gear and what kind of transmissio. Fluid do I by ,,,,,
I'll be tearing down the following list ,
Muffler
T case
Left and right Rotor mounts
Axle mount ,
Checking the right input seal as well as the ttransfer case input seal , , replace both hope it's my problem ,,,
U, no what any segestions befor I that this talon to the shop I made aappoinment With a auto shop ,,, he does work to my neighbor s camero , from what I seen , 2006 timing and front end , , paint and auto ,
