- Ownership Status
- Currently Own
- Year
- 1990
- Model/Trim
- Eagle Talon TSi AWD
- Turbo Type
- 16g
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- 6 bolt long block stock Every thing but the intake manni and exhaust. Manni that I no of ,
- Mods-Engine
- What kind of fluid do I by ,
How many seals , do I replace to fix leak
- Mods-EMS & Logging
- And running delete will that cause my engine two misfire
- Parts Wishlist
- Goal stop leak ,,,,bleed clutch ,,,, and Just two make a every day driver ,,,,saw the lay out of bleeding clutch ,,, I under stand and as forseals ,left right and tease seal , two be safe
- Background
- Put in a motor this new long block has delete lower timing , , everything worked fine slave sylender. Popped out little pin may have air in clutch ,,, when put back together, ,,, ran fine now I am leaking transmission fluid and not going into gear , I am thinking bleed My clutch , and replace the other transmission seals and my transfer case seal ,,, any advice please let me no
