Cfrakes
- 63
- 2
- Jun 6, 2021
Idaho
I got a oil leak thats above the oil filter and crank sensor and it's below the valve cover gasket and I know it's not the head gasket and idea what could be leaking out the oil? Thanks
Note: This feature currently requires accessing the site using the built-in Safari browser.
That's cause I originally had a leak coming from the crank sensor from my first post but still had a second leak after that. Took a mini camera through the back and turns out this motor has a cracked block so yeahThere is nothing between the crank sensor and valve cover gasket that would leak oil unless you have a cracked head or block. I would take a closer look at where it's actually coming from. There were times I felt confident the valve cover gasket wasn't leaking due to being new, but the factory bolts are trash and bottom out too early to achieve full torque so I had to swap over to full thread bolts. So you should start by checking there. Also making a 2nd thread for the same topic isn't always a solution. Just clutters the forums really.
