2gGst98
- 702
- 58
- Oct 3, 2010
Concord,
North Carolina
Wanted to post this as my car wouldn't start with a no crank issue, hope it helps someone else.
These are the threads I referred to for help
1.http://www.dsmtuners.com/threads/stumped-on-no-start-no-crank.416211/
2.http://www.dsmtuners.com/threads/no-start-no-crank-more-info-inside.426334/
3.http://www.dsmtuners.com/threads/no-start-starter-relay-testing.487269/
First thing I did was check the battery, tested good 609cca at 12.47v
Tested relay per #3 7th post
Tested started by hooking to 12v direct
Found 2 bad grounds that I made to my liking.
Then just removed clutch safety switch (unplugged it under dash). Should have done this first
but was having fun with trying different things.
Again hope this helps someone, if any one else has some info on no start no crank please add.
but was having fun with trying different things. Again hope this helps someone, if any one else has some info on no start no crank please add.
