zaebst
- 143
- 0
- Feb 19, 2003
Grand Rapids,
Michigan
I recently picked up a 95 awd which shortly after acquiring I realized was swapped from manual to auto. It shifts decent so no big deal right? Well I was looking over the underside one day and saw the rear diff was a JFB 3.307. I later did the old trick to verify the cover is correct and it does still have an auto rear. I panicked til I saw the stamping on the trans and got even more confused. The trans is a W5M332MMZL. I've only found a couple of threads that speculated this trans is an RVR trans. One would assume it has a 3.545 ratio like nearly everything else manual but nobody seems to know for sure.
The question is, is there any scenario anybody can think of where a manual trans would work with an auto 3.307 rear diff? The car drives fine and I tried turning the wheels while off the ground and it's definitely turning both front and rear so hopefully the center diff isn't destroyed. I feel silly asking this but I've found such little information I need to know for sure before I start tearing this thing apart for no reason.
