Morphius
DSM Wiseman
- 1,895
- 65
- Jun 9, 2003
M-Town,
Michigan
So, the intent with this, like the Holset Results thread, is to organize real world results for dsm enthusiasts that are running the (1G) Mitsubishi 14b Turbos. Post info regarding your cars setup and results either on the dyno or at the track. To keep us all honest, you'll need to include a timeslip or dyno chart for your car.
NO DISCUSSION!! Don't post comments/questions with regards to anyone’s post. It clutters up the thread. This will help many of you quickly find others that may be running your setup and give you an idea on what potential it may have
TO POST HERE:
1. You must have a minimum of (1) of the following to post:
A. Photo of your timeslip
B. A dyno chart
C. A video of your strip run that shows your E/T and/or speed
2. (SUGGESTED) Please quote the 2nd post in the thread That post is intended to be a template to use to post your info. You'll just quote that post and delete the code around my name and my name/etc so it's only the template in your post. If the line in the template doesn't apply (like you are running a stock intake and on the intake mods line, just put NA) The more info you can share, the better it will inform others down the road.
3. If interested, you can post a pic of the engine bay
4. For updates to your results, please quote your prior post. Below it, add the updated components using the same format along with the new plots or time slips.
AGAIN, RESULTS ONLY, NO DISCUSSION!
TO POST HERE:
B. A dyno chart
, completely forgot about this.
