Dyesuperman
- 523
- 21
- Mar 10, 2009
Minot,
North_Dakota
Met my current goals for the 7 Blade HX35 (run 120+ or 11s...did both) and it still has a lot left in it with a BLT, leaned out tune, and a bit of cam gear tuning. This turbo is seeing 45-50psi MAX oil pressure and is holding up great feeding from the ofh. Relevant mods (All mods are in my profile) :
7 Blade HX35 at 26psi peak for the 11.89 run
Machined T3 5-bolt turbonetics housing to fit hx35
Turbonetics manifold
Tial wastegate
VRSF fmic
Greddy bov
1g throttle body
Speed density with DSMLink tuned for E85
OEM Composite Headgasket
MAPerformance Head Studs
BSE on stock 125k mile 7 bolt block
HKS 272 Cams
Pretty sure these hurt me more than help because of how little of a sidewall they have but:
255/35/18 tires
First run of the day with a bogged launch and first time at the track with the new turbo
Raised the two step to 5k and did another pass...bogged the launch still and had to let out in second gear because of wheel hop...I knew it had more in it after this run
Final and best run of the day...11.89@120. Somewhat decent launch and didn't have to let out any. I was ecstatic to meet both of my goals for the day!
I may have more results later on but for now I feel this was more than acceptable. I haven't done a blt in months so I am sure it has a few leaks
Tial wastegate
VRSF fmic
Greddy bov
1g throttle body
HKS 272 Cams
255/35/18 tires
