mainerdsm
- 689
- 2
- Dec 16, 2009
Portland,
Maine
Ok... So I've read so many thread's of newbie's asking what they should do to thier car's first. So I thought well first thing they need to do is mantaince. SOOOO here is what should be done when you get your dsm (for the newbie's)
Link's on how to do some of these are at the bottom.
- Plug NGK BPR6ES @ .028 gap
- Plug wire's Any that aren't arcing or of poor design
- Oil Which includes engine, transmission along with if applicapable transfer case and rear diff.
- Oil filter Higher micron number the better filtration
- Coolant
- Timing Belt Kit Full OEM kit with the belt, both pulleys and hydraulic tensioner . Balance shaft belt if it's still on the car.
- Water pump Can use auto part store brand
- Air filter K&N or Vibrant Performance with adapter plate for stock MAF
- Fuel filter
- Brakes Hawk or EBC for better stopping power
- Tires Good gripping tires
- Wheel bearings Only if one of them is going out
- Ball joints (Check with dealer to see if they are in for a recall)
- Alignment
- Brake and Clutch fluid flush Dot 3
- Boost leak test
- Fix any exhaust leaks
- PVC Valve OEM only and check to be sure it doesn't leak either
- Fix any CEL codes with appropriate part
- Replace all coolant lines
- Replace all vacuum lines
- Valve cover gasket kit Valve cover gasket, half moon gasket and 4 spark plug well gaskets
- Oil cap gasket
-Un hook clutch pedal sensor (for 4g63 guys)
Boost leak test- http://www.dsmtuners.com/forums/new...se-troubleshoot-boost-leak-tester-merged.html
Fuel filter- http://www.dsmtuners.com/forums/newbie-forum/291090-omg-fuel-filter-pain.html
http://www.vfaq.net/DSM/mods/10faq.html
After that mod away.
- Coolant
- Fuel filter
- Alignment
- Boost leak test
- Oil cap gasket
