ECMlink List of Values to Log
Status
Not open for further replies.
snowborder714
Moderator
16,188
465
Oct 15, 2006
Mechanicsburg, Pennsylvania
It seems when people post up and ask for log help, there are always some values that are helpful to look at missing from their captured values list. Here's a list of values that you should have captured to make answering tuning questions quicker/easier.
If you're running SD, there will be some other values you'll want/need to log. These are noted below.
Please make sure to rename your wideband and MAP something easy to find (i.e. "Wideband" and "MAP"). This way we aren't searching for LinWB or something odd that auto-populates. Using the recommended names will also make it easier when importing into tuning programs/spreadsheets such as LinkTools.
Ideally you should just log all of these values all of the time. Just figured I'd break it down in case anyone wanted to know what values to look at for certain types of tuning.
First start up/Idle:
Necessary
RPM
ThrotPos
AFRatioEst
BoostEst
Battery
ISCPosition
InjDuty
AirflowPerRev
FrontO2
CoolTemp
MAFComp
ClosedLoop
OpenLoop
WBFactor
CombinedFT
IdleSw
TPSVolts
SelectedLFTF
VE (if running speed density)
Optional (If you have these, please make sure they're logged.)
MAP
Wideband
IAT
SDRatio (if running speed density - make sure to set up engine displacement preference for this)
Any other logged sensors (oil pressure, fuel pressure, oil temp, etc.)
Cruise:
Necessary
RPM
AFRatioEst
BoostEst
FrontO2
CoolTemp
MAFComp
WBFactor
CombinedFT
LoadFactor
SelectedLFTF
MAP
Wideband
IAT
WOT:
Necessary
RPM
ThrotPos
AFRatioEst
BoostEst
Battery
InjDuty
FrontO2
CoolTemp
MAFComp
WBFactor
CombinedFT
Timing
IntTemp
LoadFactor
KnockRet
SelectedLFTF
Torque
HP
CltchSw
MAP
Wideband
IAT
Status
