drcolt
- 76
- 12
- Jun 27, 2003
Toronto,
ON, Canada
I am in the middle of changing cams to performance cams and I figured to replace the timing belt and all seals and pulleys and waterpump, etc....... remove balance shaft. or not. I dont know the history of the motor I have. All I know is the donor car had over 530K kms on it.
I then recalled this was talked about a few years back, found this site, http://www.jackstransmissions.com/pages/keep-your-balance-shafts
That article makes a lot of sense. I believe BS failure is improper maintenance. I do have the kit for deleting, but now I am thinking I might just keep them. I am not after big hp. I do want a nice driving motor, although there is nothing smooth about the colt!
This should be a good read for new dsm owners.
There have been nissans that have had issues with knock at high rpms when balance shafts have been removed.
Porsche makes their motors with BS, as well as many other manufacturers of large displacement 4 bangers.
. But discussing ideas on ways to keep this issue from happening is always a worthwhile discussion. Now. That being said......you're wrong!!!! Lol!!! JK JK!!!!! But I do see your point. And seeing how it's almost always the belt driven gear that shows more sign of failure than the smaller driven gear, that Definitely leads to some proof of the top gear not really needing the support. We'll find out at the end of next season when I pull the motor apart after 11 races
