Black92GST
- 0
- Mar 18, 2009
Davis,
California
Hello, I am a pround new owner of a 92 gst.
First of all, my rpms jump up and down at idle, so i believe there is a vacuum leak. It seems like all the rubber hoses need to be replaced, so I will probably do that soon.
But the second thing is, when free reving the engine, if I do partial throttle from idle, the engine will die, then rev up. WOT seems to be ok.
usually people on the forum have problems with WOT or higher rpms. I have a problem with parital throttle, and leaving from a stop. the hesitation at part throttle makes the car stall when letting out the clutch.
so is this a TB, IAC, MAF problem? or can a vacuum leak cause a part throttle issue?
Here are the things I have done to the car since bought:
- Engine Oil and Filter Change
- Trans Oil Change
- Changed the spark plugs to NGK BPR6ES. the old ones were NGK Iridium BPR6EIX, they were black but the tips were light brown)
- Previous owner Changed the Timing belt, thermostat and water pump
Thanks for the help
- Trans Oil Change
Thanks for the help
