BogusSVO
- 5,886
- 336
- Jul 1, 2009
Pensacola,
Florida
I had a customer drop off a 1g 6 bolt short block, the timing belt broke and valves hit the pistons.
See where the valves hit.
Rotate the engine over so all 4 pistons are about the same level in the block.
Now take a screwdriver, stick, paint stirrer and mark it about an inch from the bottom.
Now take a cheap quart of oil, or some not so nasty used oil.
Now pour the oil on top the piston, in all 4 bores.
So it comes up to the mark on your measuring tool.
Once this is done, forget about it for several hours, or over night.
This one sat for 20-22 hours.
I had a slight drop in #1,#3,#4
#2 was almost twice as much
You can see it by eye.
Now how fast it drops will depend on a couple things, How long the oil sets, what weight oil is used and what the air temp is, along with what ring gaps are used.
All this dose is help decide if you may have a ring issue. If you go back and all the oil is gone off the top of one piston, pull that piston out.
The result of the test on this short block does not help much.
Ring wear, cylinder wear could cause a bit more to pass.
The oil is leaking thu the ring gaps, so even a good running engine will have some oil leak by.
