BLACK'98DSM
5+ Year Contributor
- 4,542
- 1,959
- Feb 9, 2019
Alabama
Just wanted to share a bit of what's happening in my home garage. In the midst of fully rewiring and refinishing the interior, I also decided to switch up the material used to cover the walls. When the place was built they used some sort of cardboard-like paneling that really sucks for a garage. I could never get paint to stick to it, it swells up from any moisture in the air, it's extremely soft and thin so easy to damage. Had to get rid of that. I considered sheet rock but have that installed in my other garage and it gets really beat up. Any time it gets bumped with tools/toolboxes or car parts there's a new dent or hole. It sounds easy enough to be careful around the walls but sometimes they take a hit outside of my control or attention. So after consideration I decided to use OSB for the new setup. I tested a piece by knocking it around with a hammer and it's nowhere near as fragile as sheet rock. It is also considered a decent moisture barrier which is why it gets used under roofing I suppose. I think if I were to coat it with semi gloss black or dark grey paint, the look would be very nice. Especially with the wall decorations I have planned. A dark color may be a little too dark for the taste of some, but I've accrued many dark finger prints and stains on my lighter colored garage walls. I did install full LED strip lights to brighten the place up anyway. I've still got to remove a ton of unnecessary electrical before the entire wall goes up but with the first 2 pieces I'm still liking the idea. The texture is ugly with bare board, but will probably look alright once fully black or grey.
I'm not a builder or contractor by any means, but definitely needed to figure out a better wall solution. I can at least cut wood for God sakes.
