ForcedFour SmartShift 100.1 review PART 1 of 2
1990TSIAWDTALON
Moderator
13,316
11,373
Nov 14, 2013
Independence, Kansas
Ok so mine definitely will NOT connect KOEO. It connected running but the rpm signal keep dropping out? Like it would freeze. I'll attack some pics of my interface. I tried setting the TPS but....how do you save changes? Your interface has a button "save changes" mine supposedly says it saves as changes are made but I'm seeing no change in behavior. Car is still in 3rd/limp mode.
I'm running to pick up a buddies short block from the machine shop. When I get back I'm going to download your version 1.21 and see how it acts. It's almost like the box doesn't want to communicate? Possibly a bad shift box?
There have been a few bad ones but Shawn has always taken care of them as far as I know.
On your screens, try this............at zero throttle, press the "set 0%" and then (you can't do this since you have to have the car running, that is a BIG problem) mash the gas to the floor and press the "set 100%" button.
Really, the box should work with Key on ignition off though so maybe you have a box that has an issue.
