EVO 8 MAF with 1g can?
4gfun
Supporting VIP
2,012
56
Dec 10, 2007
Ask Me, Virginia
I am expecting an EVO 8 399 MAF shortly. I was wondering if anyone knows how to adapt a 1g can to an EVO 8 MAF?
I have put some time and money into my 1g can. It is all pretty and coated with POR 15. I have also invested money in the air filter on it.
I don't want to spend any more money in that area if I can avoid it.
I see that people have done it on these 2 links here but both seem like pain in the necks and perhaps not that pretty or reliable. I am willing to chance it but would rather have some thoughts first:
2G MAS using 1G Filter
3G or EVO MAS wiring | Galant VR-4 > How To and Info Archive | GalantVR-4.org Mitsubishi Galant VR4 Forum
Also, the end of the MAF is the same on both the EVO 8 and 2g MAF correct?
Just want to know if the same procedure would apply for both because the 1st link is for a 2g MAF.
Thanks for any ideas.
What do you mean the "face is different"? I guess for all intents and purposes it doesn't really matter since it is the same bolt pattern?
I appreciate your help, thanks for chiming in.
Very similar, same bolt pattern but face is slightly different.
Yes.
The intake will fit perfectly around the EVO MAS, 1g/3g/EVO are all 3.125".
Dejon Powerhouse has a solution to adapter the 1g filter to a 2g MAS. This might be a solution for you.
DEJON | Powerhouse
The 2g/3g/EVO MAS all have the same style flange for the filter, 4 bolt square setup. The difference is the intake side, not filter, 2g is 4 inches and 3g is 3.125 as stated above.
My suggestion is since dont have much room to work with in a galant, even less room than the 1g, i would buy a filter adapter for the 2g/3g/EVO MAS. They can be found to adapter the square flange to 4.5" and 5" filters. It looks just like this:
I know you dont want to spend more money and want to adapter the 1g filter, I am sure you can do it. I just found that using this hardware helped with the tight fitment. I know you saw my picture from the other thread, I had to use a pretty short filter for it to fit properly.
I used an adapter harness for the EVO MAS, I know people on Galantvr4.org sell them. I got mine with the filter form DSMchips.com a while ago, they are no longer in business.
http://www.galantvr4.org/ubbthreads/showflat.php?Board=UBB1&Number=817903&page=0&fpart=1
As always agentorange...thanks for your posts. They are always very thoughtful and thorough. You are appreciated. BTW what thread were you referring to? Also, I don't see that adapter plate on Dejon's site.
DEJON | Powerhouse
FS: 1g to 2g/3g/ Evo MAF/MAS adapter harnesses | Marketplace > Parts For Sale | GalantVR-4.org Mitsubishi Galant VR4 Forum
Ahh yes that post... :)
In a daze, always something going on with these cars...easy to forget. Thanks!
http://www.dsmtuners.com/forums/new...f-but-i-am-getting-overrun.html#post153251390
The second picture is of my DSM,I was referring to fitment issue, but your filter is in a different location. I wanted to show that I needed a short filter for it to fit in my engine bay area. This is the filter I am running.
EXTREME PSI : Your #1 Source for In Stock Performance Parts
On Dejons site, click 2nd Gen intake pipes, then click the picture of the filter and adapter.
