Driveshaft & Transfer Case Fitment Help
motozachl
1,249
20
Jul 15, 2008
Cleveland, Ohio
My driveshaft isn't going all the way into the transfer case. I took it off several months ago to get to the oil pan bolts. Now I slid the shaft back into the case to put it back on and bolted it back up. Well the driveshaft it sticking out about 1.5-2 inches. I can pull it into the case but it just springs back out because of the middle driveshaft mount boot. Am I missing something :confused:
Did you know how much slack there was before you pulled it out?
Sounds normal to me. There is an inch or so of play where the yoke goes into the transfer case. Eliminates the problem of bottoming out in case of engine movement.
I'm assuming the car was drivable before you pulled the driveshft. If the transfer case is bolted up and the driveshaft is installed, you should be good to go. There isn't anything you could do wrong. The driveshaft slides back and forth on the transfer case shaft.
Since you have it hooked up, try driving it and see if things work. Worst case you have to put it back on jack stands BUT you'll then have different symptoms to describe that we can help you with.
For the splines not to engage, the driveshaft would have to be pulled out of the transfer case to the point where it's falling out. Check the splines for damage. While you're down there, you may as well see if there's maybe some kind of suction thing going on in your C/V joint at the back of the driveshaft, because I thought the shaft was supposed to spring toward the T-case, not away from it.
If you got the splined hub with the snapring into the gearbox and the wheels spin, it is possible the cv joind discombubilated and that's why the extra spacing. The balls are out of the joint. It is possible to put it together by getting personal with the boot with feel. Next, If the joint will not go into the trans case, sometimes a knock on the axle end will push it in. It clears the snapring. This is of course, if the joint is not discombubilated. Tres..
Alright so I took some measurements so I anyone could go out and double check theirs that would be :D
As it sits - 1.25
When I pull is out 1.75
Pushed in .75
Here is a pic of it currently
I just put my T-Case up last night.
I had the same issue.... but I give it a tad bit of force and it popped right into place.
Your Diveshaft isn't dangling on the ground is it? D;<
Popped into place? Can u check the measurements with the ones I provided please? No it's definetly not sitting on the ground and can't pull it all the way out either.
Side note: ship me that fender ###zz
The picture looks normal to me. Looks like you have about 2-3" of it in the transfer case. Not sure how long the yoke is.
