burntheblobs
- 133
- 2
- Feb 4, 2004
Lafayette,
California
The alarm on my car will be set off lately for no reason at all. Even when I don't arm it. It will all of a sudden, for no reason, just start blaring.
Note: This feature currently requires accessing the site using the built-in Safari browser.
steve-o_95_GST said:I had that problem and after a few nights of it going off around 2 am I decided to look for the problem. Under the hood right next to the drivers side head light there is a bracket with a black boot on it. Thats the hood switch for the factory alarm, over time that bracket gets bent down and the switch doesnt get depressed far enough. If you bend it back up alittle it may solve your problem, it fixed mine so its worth a try.
-Steve
burntheblobs said:What if it is the stock alarm? I'd also like to note that this happens at a random time after I've stepped away from my car. Anywhere from 5 seconds to 5 hours later. Also, the sound it makes isn't the normal sound. It doesn't cycle through different annoying sounds like if someone opened the door with it armed. It just honks the horn repeatedly and blinks lights. Maybe some sort of panic mode is being activated? I do know that my alarm button isn't what it used to be. Sometimes the terminal on it pops out of its little computer and I have to crack open the remote and push the terminal back in to make the alarm remote work again.
-Steve
whiteflash said:I had the same problem, did the same thing except i just unplugged the little boot thingy and ziptied the cable, problem solved....
GVR4592 said:I had the same problem on my Galant. I just replaced the switch and all is well.
