2gNT PCM Connector Views
Doug99RS
DSM N/T Wiseman
DSM Wiseman
2,020
29
Nov 10, 2002
Raleigh, North Carolina
Here's the PCM connector views for the 2gNT
The 95 models use a single 60 pin connector.
The 96 and newer models use two 40 pin connectors.
For 95, Orientation is:
60-41
40-21
20-1
Orientation is that pin one is lower right corner as viewed in to the connector pin itself with the connector unplugged.
Connector on left of picture:
31-40
21-30
11-20
1-10
Connector on right of picture:
71-80
61-70
51-60
41-50
Orientation is that pin one is lower left corner as viewed in to the connector pin itself with the connector unplugged. NOT from the backside following wiring in to the PCM like you find on almost every other manufacturer's diagrams.
