1G 2g trans works in 1g?
TimF
821
7
Mar 14, 2011
Aurora, Illinois
I looked for a bit and only found info about fwd and 1g in 2g, but would a 2g fit in a 1g with a 6bolt motor? I need a trans for my shell and there is a local sale on a used racing trans for a 95 awd, but I dont want to buy it if it wont work or will be a big hassle to install
its an easy swap... you may or may not need to tap a bolt hole on the top for your 1g mount to mount too... and some people have to bend an arm for the shift cable..but in all honesty I've done this at least 3 different times and not had any of those issues... You will need to use your 1g speed sensor obviously.
I believe 2g have a double syncro 2nd from the factory .. and they "seem" like they have a closer H pattern when shifting VS the 1g trans but I've never actually measured the throw..
Otherwise its just availability
would I still use a 6bolt flywheel clutch ect, or 2g ones? sorry my first dsm was an auto so I am unfamiliar with this
got the trans yesterday, next question is can I use the original 91 tcase or do i need a 95 tcase(year the trans came off of
As long as the output shaft is 23-spline and the transmission is a 1991-1996, then you can interchange any year 1991-1996 5-speed transfer case. 1990-early 1991 22-spline tcases and 1997-1999 tcases will not work.
ok another thing I am wondering is I have a 90 fwd parts car with good shift cables, and the one's that are on my shell just are not as clean and missing the rubber inserts were they connect to the trans. I was just going to swap them into my shell, but I read that the 90 cables are different and I would have to change the brackets ect. Were would I be able to get those inserts or should i just run the 90 line
We did a 2g Trans in my brother's 90 AWD and his shift cables worked fine.. I forget which bracket we ended up using though..
what trans mount bracket would I use? a 1g or 2g? I have the 1g poly mount but the trans does not have the bracket to attach it to and I am unsure what one to use
well the 2g bracket does not fit, so that was a waste of money.
Ok so I have the stud and a hole after that, the stud fits through the hole, but the second hole does not line up, so just I just drill out a hole? and even then the mount will not sit flat against the trans. This is the only thing keeping me from getting my motor in my car, and I am already behind in getting my two cars done. Can anyone who has done this give me more input ?
Should just bolt right up. My awd 1G had a 2G trans in it all with the 6-bolt flywheel. I needed the 2g starter plate. My 1G fwd also had a 2G fwd trans in it. The fwd 2G trans uses bigger diameter axles. The awd is all the same. I also used my 1G mounts and brackets.
Fwd to fwd and awd to awd for the mounts.
That helps a lot. So you can't use a 1g starter plate cause thad what I got
Ok I got everything good now, my last question is do I need a 2g starter then?
Ok so the trans is on, but the dowl right below were the starter goes does not have a bolt hole, its no fully attached. Sorry I can not post pics but how do.I tighten that down?
  • For sale Carbonetics Carbon Quarter glass
    Bnew Carbonetics Quarter glass
    • jabo97gst
  • Wanted 1g Wtb: Palm pilot w/ MMCD and cable
    I am doing an old school build with my 1G and am looking for this ancient hardware. Preferably...
    • Jeff D
