2g ecu into 1g
95tale
110
Jul 26, 2013
hamersville, Ohio
Could I put a 2g ecu into a 1g? if so what are the steps if any. Also I have a 2g maf I want to put on my 1g. how would I do that?
It could be done but you would need a 2g engine harness, and would have to do some wiring to adapt the harness to the chassis harness. A 2g maf swap is easy, but you will need at least 550 cc injectors and an AFC, and a 2g maf plug or power transistor plug
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
