sunflashx
- 347
- 2
- Jun 1, 2002
Utah
This all pertains to 91 octane pump gas, not race gas. I am also located at 4600' Altitude.
There aren't any local 1g's in town running bigger than 550's, so I have no one to refer to.
My base pressure is set to 38 psi to lower the timing a bit from the previous 43 psi I had it set at. My car feels the strongest (by far) and has the best feeling power curve when I get a bunch of timing retard from a 10-15 knock count or so. That knocks my timing down to the 17-19 range, I think a no knock run will land my about 24 max degrees of timing. I am also running about 19-20 psi in hopes of the higher airflow lowering my timing, I'm not sure that it made a significant difference in the amount of timing I was getting over running 16 psi.
Full list of modifications can be found here:
http://utah.dsm.org/members/sunflashx.htm
