NJGSX96
- 745
- 2
- Dec 11, 2001
YMB,
New_Jersey
Well the other day I went out and bought a new alternator and battery for my 1G. Of course the bolt for the alternator was in backwards and couldn't come out without removing the turbo/manifold/O2/exhaust, but thanks to my friend Phil and his Sawzall, that was a minor issue. Anyway, when I went to the parts store, they had a 75AMP and 65AMP. The 75AMP is for automatics, but was identical to the 65AMP, which was for manuals, so I went with the 75AMPer. Why not, right? Get it installed, everything plugged in, clean up the battery connections, install the new battery, fire it up, all good. This was Monday. Tonight after work I go back to the car and figure I'll add some goodies I got for my b-day while the car is down. About an hour later I have installed my nice new cockpit adjustable hallman MBC and I swap out my plug wires for the NGK wires I had on before since my Magnecors bit the dust... again. That is it. I do nothing else. Plug up the laptop, start the car, fire up TMO, log battery. 5 seconds into starting the car I hear a high pitched occillating whine and with it the lights are dimming and brightning. TMO battery log looks like I am logging O2 dipping to 11v and rising to 14.5v over and over. Finally steadies at 13.9v and the whine becomes constant, whih is coming from the alternator. I let it idle for 10 minutes. All looks good. I got out for a little test drive and as soon as I get to the bottom of my hill the log shows 12v and i can see the lights dim! Every time I come to a stop it dips to 11v and the dash lights for battery, coolant come on, then go off. I get back home as quick as I can, and park it. At this point the lights are all dim and the log shows 11.6v.
Is this for real? Is my alternator already f#cked up? In all my years of driving I have NEVER had to replace an alternator. is this common for them to die or come bad out of the box? Is the 75AMP not compatible with my car? Where the f#ck do I start to check now or is it just the alternator?
