firebirdvert305
- 387
- 8
- Mar 6, 2005
Davenport,
Florida
Well ive been dealing with this problem ever since I threw the Evo 316G on...It will not hold boost for anything at any given psi, so I really have no resort, but to go external WG which i dont mind. People say If I would of ported the flapper door or go 34mm flapper it woulda solved it, but also alot of people remove there turbos, go 34mm and cant run high boost/or it will still creep. My question is to you guys which would be the easiest route to go external? Would it be buying a new 02 housing (punishment-racing.com) flanged for a tial 38mm wg? Downside to doing it this way would be that, on the turbine housing side its still very limited exhaust pressure with 31mm flapper, and would probley need to be ported out in order to work well? Would it be better/easier to flange off my Evo 3 manifold,#1 runner or collector? Lemme know which is the best way to go here, any info is helpful thanx guys.
