Luke223
- 66
- 1
- Dec 22, 2002
Albuquerque,
New Mexico
I have a 92 Turbo Laser (6 bolt) and was attempting to install a new turbo with a dry housing. I bought the NT parts (lower thermostat housing and water pipe) to eliminate the coolant lines going to the turbo. But the water pipe I got also eliminates the coolant hose going to the oil filter housing.
The thermostat housing has a spot for a nipple for the hose that goes to the coolant line into the oil filter housing, but it is in the wrong place. It appears that the thermostat housing eliminates the oil filter coolant line then off to the side there is a threaded hole for a fitting that would connect the oil coolant line. I would need a fitting that would thread into that hole with a nipple to attach the hose.
I have read that other have used the NT parts to eliminate the coolant lines going to the turbo, what am I missing?
